Battery charge and alternator at cold temperatures
  • Zetaimmersion
    • Dec 2019
    • 3
    Have a '88 325i with an odd battery issue (to me) which happens only at cold temperatures.
    When I start the car 3 lights are on (parking brake, brake fluid and battery). When I start driving they stay on and sometimes never go off. Radio and the computer don't work either.
    ​​​​​​If the above happens, the battery is usually dead in soavout 10 min if I don't stop and start the car again.
    The lights go off only when I hear a woshing sound from the back at which time everything is working.
    Anyone have any clues as to what this could be? Alternator or something else?
  • doctorx
    • Mar 2019
    • 65
    I had this exact issue. It turned out the alternator was bad. I tried changing out the VR first and didnt help. Only cleared up once i replaced the alternator.
    • jbontke
      • Mar 2019
      • 449
      Take the alternator off and have it checked at a parts store. I tested an alternator on a focus that charged at 14.66 volts. Took it to the parts store for testing and found out it was actually bad. The reg and rectifier were bad.
      • Zetaimmersion
        • Dec 2019
        • 3
        Awesome. Thanks guys. Will give with a go. Did notice with the help of another member here that if I go up to 3k everything starts working fine and the battery is not loosing charge anymore.
        This is resolved. Much appreciated.
