2nd blue C1 connector? 85 eta
  • Italian_Tuneup
    • Sep 2018
    • 128
    So I was an idiot when I tore out the dash and didn't label a bunch of connectors. I have the Blue C1 connector for the cluster, which is obvious due to its length and its strapped to the column support.... but way further out by the green OBC connector I have another identical looking blue connector. I have no idea what the hell this came off of. I don't thunk it's the idle control module, because that used larger pins I think. All that stuff is long gone. I toned some of them, and a bunch just apear to be hot in on, so I have no idea what module this went to. Anyone know? Thanks.
    1985 325e -> M60 swap project
    1983 GTV6
    1974 X1/9
  • tomstin
    • Mar 2015
    • 568
    Cruise control?
    2004 525i Manual - 1985 325E Coupe Manual
    • Italian_Tuneup
      • Sep 2018
      • 128
      Originally posted by tomstin
      Cruise control?
      I thought that module was on the firewall above the clutch pedal area?
      1983 GTV6
      1974 X1/9
      • Italian_Tuneup
        • Sep 2018
        • 128
        I stand corrected. Tomstin you are correct, it goes to the cruise control module, that mounts........someplace.
        1983 GTV6
        1974 X1/9
        • tomstin
          • Mar 2015
          • 568
          Glad I could help. As I recall, the cruise control module mounts by the ECU over the glove box but has a connector on the instrument cluster as it needs to monitor speed, brake and clutch pedals.
