Idle Control Valve
  • ThomasE30
    • Mar 2020
    • 104
    Idle Control Valve
    SO my stroker E30 runs loud and idles high and I was told it could be the idle control valve going bad. I had a BMW mechanic friend take it out and he told me the rattling that was supposed to happen was quiet because it was clogged with carbon. Seeing as how a new one is $600 from auto zone, would I be able to find one from an e46 or something around that time? I didn't know if they were interchangeable or if they used a different part.
  • roguetoaster
    Biggus Tippus
    • 7829
    Don't buy parts from the local stores, they'll tuypicall be low quality and overpriced. Use bmwfans.info or realoem for part numbers/interchanges. Test before replacing and buy good used if on a budget.
    • cheffy30
      • Sep 2016
      • 1159
      Blast it with brake parts cleaner. See what happens. Mine is 30 years old... Been blasted several times... Idles perfect. sent from hell using tapatalk
      '90 325i sedan daily driven
      '85 325e coupe also a daily
