fan switch on radiator question
  • mentaleeill
    • 850
    i read it in a post awhile back, but don't remember which one. the search won't let me look at page 2 or higher, so out of 800 or so matches i can only see page 1. i have a m50 in my 89 325i and was wondering if someone could tell me which wires from the car harness go to which pin on the e36 switch?
  • ian332isport
    • 124
    Are you using the early or late E36 switch ?
    The early E36 switch has the same style connector as the E30, the later one is a bit smaller with tiny little pins.
    Ian.
    • mentaleeill
      • 850
      the radiator is from a 94 318i. it has 3 pins in a funny looking triangle pattern. the car has 3 90 degree loose connectors on just the wires
      • mentaleeill
        • 850
        nevermind i found it. thanks anyway
