No start issue, unresponsive cluster and AC
  • Yooestiben
    • May 2020
    • 4
    Hey guys, I recently picked up a 1988 325. I was pulling apart the interior doing a deep clean and found the wires to the shifter light were tampered with and while moving around I think they shorted out because I heard a small click. Now, the AC does not come on and car does not start. Fuse 20 is good , i put a new 30 amp just in case but still nothing.already tried jump starting the car and no luck. Radio, clock, hazards and cluster all still light up. I was able to jump pin 11 to pin 14 and got the car to start with the key turned. While on the cluster is unresponsive unless I have the pins still jumped. Same for the AC system. What should I be looking for or what can be my issue?
  • tomstin
    • Mar 2015
    • 569
    How is fuse 10? Looks like that has the neutral safety switch (automatic transmission range switch) which is the area you were playing in.
    2004 525i Manual - 1985 325E Coupe Manual
    • Yooestiben
      • May 2020
      • 4
      Thank you so much, that was it. I looked over the fuses and that looked fine when I checked it but at the very corner it turned out to be popped.
