Fuel tank rust?
  • natefoo
    • 31
    Fuel tank rust?
    I’m trying to get my E30 back on the road after a couple of years parked and a couple more not being driven much. The last time I had it out a year or so ago it started and warmed up fine and drove ok until randomly cutting out and almost but not completely stalling. It’d backfire but not die. I shut it off for a few minutes and was able to drive it home with a couple more stops.
    Online suggestions were rust in the tank or other fuel delivery problems. I finally popped the pump out today to take a look and it’s rust-colored in there but I don’t see any sizable rust particles, even trying to stir stuff up off the bottom. Does this look bad?
    This could also just be bad gas? I stupidly parked it with a full tank of E10 and didn’t put in any stabilizer so it’s had that garbage in there for 3+ years.
  • roguetoaster
    Biggus Tippus
    • 7815
    Yep, sounds like bad fuel. Empty the tank as much as you can and pump the fuel through the lines to a convenient place up front with the ignition disabled to clear them. You can omit the second part if you want.
    • LowR3V'in
      • 4209
      old gas turns into a super dark piss color just like that.
      • natefoo
        • 31
        Awesome thanks, I’ll drain it and hope for the best.
