Gauge Cluster fun.......
  • bimmer8604
    • 3017
    Allright. Got my new car, everything is cool, except for the guage cluster:
    The whole right side (tach/mpg/temp) does not work. The oil service indicator light WONT go off even after resetting them.
    The Odometer doesnt work. I swear the first time I test drove the car it had 120k on it. Now it has 103k and it wont work. Oh well, stupid people. Guess I need to report that to the DMV.
    Ok, I am thinking about just switching the guage cluster from my old car into the new one, do you think that will solve my problems? I think the deal with the right side of the cluster and the SI lights are because of the SI batteries. The ones in my old car worked fine, so i hope that fixes it. And i think the gears in the odometer are stripped out.
    Any other suggestions? Id rather get the one in the car working so i dont have to deal with reporting milage and stuff and dealing with the people at the DMV.
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • M-technik-3
    • 18946
    Sounds like someone was rolling back the odometer, it's not hard at all. Or the swapped cluster with a bad one they had lying around. Bad becase it might just need SI batteries.
    • Brew
      • 3060
      You can try putting the front half of your old cluster, including the si board, onto the rear half of the new cluster. My tach would not work after I finished the m50 swap and I traced it to the si batteries.
      '91 318is
      • bimmer8604
        • 3017
        Yea i think her mechanic tried to set back the odometer. I have taken my car to his shop before and they were supposed to replace both control arms, well, he replaced one, with a USED control arm. Got my money back tho.....bastards.
        Kyle
        DILLIGAF
        • BS87
          • 1606
          Heh, my tach just died today... ONLY the tach/MPG guage though, i'm pretty sure it's a loose ground nut on the back.
          • robert325is
            • Aug 2004
            • 1171
            yah i have the same problem... tach/mpg gauge doesnt work.. sometimes it does but its crazy revs.... like 1000-5000 rpm at all times... at idle... and i still havent gotten around to putting in new batteries
            • Fred
              • 659
              There is no ground nut for the tachometer.
              '86 325 2.8i stroker - Arctic Blue
              '11 328i Sports Wagon - LeMans Blue
              Strictly Eta
              • robert325is
                • Aug 2004
                • 1171
                i pulled out my SI board today and there was battery acid all over it... whole middle of the board was shorted out
                • BS87
                  • 1606
                  Hell, there goes my plans for an easy fix. BAH, this weekend should be fun.
                  • M-technik-3
                    • 18946
                    Sorry I just thru a SI board away two days ago.
                    • rs4pro3
                      • 5808
                      I've got 2 early ones in the attic not being used $10 shipped
                      85 325e 2.7 ITB'd stroker
                      • robert325is
                        • Aug 2004
                        • 1171
                        i ordered a rebuilt one from BMA yesterday right after i pulled the board out...
                        • Erick
                          Official R3V Drifter
                          • 11169
                          If your fuel gauge took a shit as well, it's probably fuse #10.
                          ..::Support FullOpp::..
                          FullOpp Stickers for sale!
                          Feedback Thread
                          • BS87
                            • 1606
                            Mine was fuse 21, my father forget to tell me he took out the trunk light while i was working on the rear bumpers. Thats fine, don't want to drain the battery. What he didnt tell me was the fact that he accidentally grounded the wires to car somehow and sent sparks flying, thus popping the fuse :roll:
