Hey all,
wondering if anyone has had this ABS Issue before. Turn the ignition on and ABS light is on like normal, start the car and it goes out like normal. Rev the engine up in neutral and the ABS light will come on and stay on. Turn ignition off and start engine ABS light goes off again, rev it up again in neural and it will come on - and repeat.
As above if I start the engine the light goes out, if I start rolling with the clutch ABS light won’t come on at all and system works normally, works normally for the duration of the drive no issues. It’s only if I rev it up at idle.
has anyone experience this before?
I know the abs is simple - light comes on when moving then ABS sensor likely, light comes on and stays on then likely control unit/relay/wiring but it’s none of those.
1988 convert 325i
1988 convert 325i
