replacing control arms and bushings, here is what I learned
  • clydesdale
    • 631
    Buy the friggin crows foot for the passenger's side ball joint and make the damn puller tool to push the bushing onto the arm. No way in hell I could have used a stubby to remove the nut on the passenger side ball joint. It took me 4 hours to remove the one nut with a standard 21mm wrench. I had to put a ton of torque through it. A stubby would never have gotten the job done. I also could not push the bushings back on, I made the puller tool that you see in this link.
    Buy the crow's foot and make the tool. YOU WILL SAVE HOURS!
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    Sounds like you needed a "taco" wrench.
    And you can use a jack to hold the ball joint up in there.
    -Andy
    • Aptyp
      • 6584
      maybe... just maybe... because that bolt is supposed to be 22mm???
      I know it takes forever, so I lift the motor and use 7/8 self wretcheting wrench I got from Sears. It's awesome and easy.
      As far as getting lollipop of the control arm, I do it with both boll joints still in. Use two pry-bars (crowbars) to press them off in the car.
      • guibo09
        • Dec 2008
        • 834
        why not drop the subframe? took me less than 1 hour to do so with a jack holding the engine up. then you have excellent access to the bolt and take it off with whatever you please *insert impact wrench*
        90 E30 325i
        • Liam
          • 753
          It's nice to have all the right tools, I suppose I'm spoiled.
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • txtorquemade
            • 1758
            Tools rulz... Im thinking
            sigpic 1987 325is
            • clydesdale
              • 631
              I remember reading on here about the 22 mm. But I will tell you it is 21mm on my car all day long. I have check with a socket head as well. The 21 fits like a glove, 22 is too loose. The new nuts, same deal, 21 mm socket. The crows foot was the deal. I had no problem once the one nut came off. Everything else pretty much fell out, with the slight help of air forks.
              • Naplm00
                • Nov 2008
                • 1573
                mine was 22mm as well,
                i just used an offset O2 sensor socket to get it off/on
                and i used my press to install everythign else
                88 325ic ~~~> Rusty and ugly
                85 E ~~~> RIP
                • kronus
                  • Apr 2008
                  • 13022
                  So I guess I'm the only one reduced to doing maintenance using branches and little bits of string as tools, eh?
                  cars beep boop
                  • free
                    • Dec 2008
                    • 55
                    Kronus, I am with you. Took me a long time to change my control arms. I won't tell what tools I used in some places....
                    • Swart_Kar
                      • Nov 2008
                      • 60
                      PB Blaster really came through for me in the end. I was using a breaker bar on the ball joint fork and it did not budge. I sprayed some of the blaster on there, let it sit for 15 min and a tap with the rubber mallet and it was free. Just beware that you can put the lollipop in upside down. What can I say, it was a late night. :)
                      2002 E46 330i
                      2008 Jeep Commander Sport
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        Has anybody pressed out the balljoints from the control arm and replaced just the balljoints?
                        I noticed that BMA sells the balljoints by themselves for alot less than a whole control arm, and I'm tryin to lowball some work lol (already $700 into my old '84 eta I'm fixin up for my little brother) I have access to a 20 ton press at work btw or i wouldn't have asked.
                        '89 Alpine S52 with goodies
                        • Naplm00
                          • Nov 2008
                          • 1573
                          yes its doable
                          85 E ~~~> RIP
                          • Cobra Jet
                            • Apr 2008
                            • 278
                            Yes, I've also priced out just the ball joints for the front LCA's - and depending on what brand/manufacturer and vendor you decide to purchase from, you can replace all (4) front LCA balljoints for under $80.... as opposed to spending in excess of $200-$300 for front LCA's...
                            I'm not really sure why one would "overspend" replacing both L&R entire front LCA's if the actual steel arm is not bent or damaged... It just seems like a waste of $$$ IMO when one can just R&R the ball joints from the LCA's. If you don't have the means or tools for R&Ring just the ball joints, any local garage or shop would be able to press out and press in new BJ's for a walk in customer, should'nt cost any more than $40 or so for them to do it...
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              I just got the balljoints from BMV up here in Canada cost about $140, let's see how stubborn those bitches are when I press the old ones out.
