E30 AC retrofit, how to wire upgraded condenser fan?
  • maxG
    • Aug 2017
    • 18
    I'm doing the r134 retrofit.
    I've read many threads, some update to newer fans, some stay with the current one on their old condenser.
    I bought a new fan per one of the how to threads, but didn't even think to ask why. It seems sticking with the og fan is a straight forward condenser swap. But I've read the newer fan I got off Amazon is higher flow and results in lower ac temps.
    ​​​​​If this is true, the next question is how do I wire it in to work properly? Everyone seems to gloss over that in the how to's. Will I lose any functionality like dual speeds with a new non oem fan?
    i thought it would be a simple one to one wire splice. But looking at the wiring bundle to the existing fan, there are more wires. Some go to what might be a resistor mounted to the old fan. Do I keep that with the new fan?
    Formula SAE Alumn
    2002 SVT Focus- Mrs. Daily
    1989 Alpenweiss 325i sedan- My Daily
    1994 Red Miata- Her's
    2003 Electron Blue Corvette Z06- His
    I like to Fly ;)
  • tomstin
    • Mar 2015
    • 564
    You can wire it the same as stock one. The resistor permits two speeds when the temperature gets hot.
    2004 525i Manual - 1985 325E Coupe Manual
    • maxG
      • Aug 2017
      • 18
      Ok that's good to know. Is the common experience that the stock one doesn't typically flow as much as the aftermarket ones? I got a 14" 2400 cfm fan, but have no idea how much the stock one flows. I prefer keeping this stock if it's good enough and better quality.
      Thx in advance.
      Formula SAE Alumn
      I like to Fly ;)
