Overheating
  • Matto
    • Jan 2004
    • 800
    Overheating
    Other than thermostat and the radiator needing to be flushed what could cause overheating in my m20?
  • FergU
    • 43
    Water pump, clogged heater core, or heater core valve
    • Matto
      • Jan 2004
      • 800
      Just changed my water pump and that wasnt the problem, so I guess that leaves the heater core.
      • coupeowner
        • Oct 2004
        • 50
        Could be the fan clutch too. If it is heating up in stop-and-go traffic, but cooling at speed, I would suspect the fan clutch. If always heating up, most likely something in the coolant passages is blocked.
        • M-technik-3
          • 18946
          Could be a dirty radiator also. Leaves and oil and dirt blocking fins.
          • Jand3rson
            • 37587
            That's EXACTLY what mine is doing. How do I test the fan clutch?
            • M-technik-3
              • 18946
              Does it spin at start up and stay spinning? Next you roll up a big section of newspapers and stick into fan blades, if it stops then it's still good. But it needs to be done while engine is cool.
              • Matto
                • Jan 2004
                • 800
                My radiator is fine, i just flushed it and i did the fan delete mod
                • M-technik-3
                  • 18946
                  OK you did a fan delete and you have cooling issues? Now your confusing me. Did you add cooling capacity? or an electric fan. Orr why was your car overheating to start with?
                  • Jand3rson
                    • 37587
                    If the fan STOPS then the fan clutch is still good? I was told the opposite before.
                    • e30Matt
                      • 5077
                      Yeah... if the fan STOPS your clutch is bad.
                      But rather than replacing the fan clutch, just buy a lower temp switch and delete it altogether.
                      I'm only running the aux fan and never see the needle approach the center mark.
                      • Matto
                        • Jan 2004
                        • 800
                        I added an electric fan.
                        • coupeowner
                          • Oct 2004
                          • 50
                          Just to clarify. The newspaper test I know requires the engine to be warm (fan should be engaged) and if the newspaper can stop the fan, then it is faulty. It should be pushing a bunch of air. If it is weak, your fan clutch is slipping, and not providing the air movement it should.
                          • kansas-ix
                            • Jan 2004
                            • 1600
                            Small head gasket leak could be your problem, I just did my head gasket because I was having these same issues and the 3rd head bolt back on the intake side wasn't torqued correctly and was causing a small pressure leak forcing antifreeze out of the engine causing it to heat up. Once I get the car back from the shop (tranny work not the head-DIY) I did a nice paint job on the intake and valve cover I'll post.
                            E30 325ix 62k
