Feul pump fuse blowing
  • kokiyufo
    • Jan 2021
    • 1
    Hello out there
    Need any info I can get on 87 BMW convertible blowing #11 fuse . Starts up runs fine for few min. Then pops fuse. Checked pump, relay,grounds, crank sensor . Put out 11 volts at pump and 13 at hot side of fuse any ideas why it would blow fuse?
  • tomstin
    • Mar 2015
    • 568
    The pump is probably on its way out. As it runs the resistance increases and eventually blows the fuse. You could try cleaning the contacts on the relay and fuse holder, but I doubt it will work.
    2004 525i Manual - 1985 325E Coupe Manual
