Any one removed the Charcol canister?
  • rs4pro3
    • 5808
    With doing the m30 engine swap I'm thinking of removing the charcol canister and just venting the fumes, How should I do this? vent them into the engine bay? Vent it back by the filler tube?
    85 325e 2.7 ITB'd stroker
  • BS87
    • 1606
    I think Jordan has.
    • DaN
      • 1265
      Better watch your back, the epa will be all over you now.
      You're on the list....... :shock:
      • Jordan
        • 12916
        Yeah, I bypassed and removed mine. Connect the line on the fuel rail directly to the valve on the bottom of the TB.
        https://mtechniqueabs.com/
        • rs4pro3
          • 5808
          Well the m30 dosn't use a purge valve like the e30.
          I'ts just the canister and then the intake manifold.
          So you're just venting right into the intake manifold with no Charcol Canister?
          • Jordan
            • 12916
            That is correct.
            • rs4pro3
              • 5808
              Ok thanks, I'll stop by the dealer today to get the line.
