Under Dash Wiring - Airbag models only *photos added
  • jrobie79
    • Mar 2006
    • 2526
    Does anyone have any pictures of the brackets and connectors under the dash - I just replaced a bunch of floor panels, and the firewall insulation and I'm having a tough time putting it all back together. before I put the new dash in, I want to make sure I have all the wire harnesses fastened to the body/brackets.
    I can't figure out where/how the ignition harness connects to the body. I believe it slides onto another big plug, but all the pictures one seen are non airbag cars and the mounting tab on the column looks like it's rotated 90 degrees from how mine is
    Update: where do these plugs go/relays mount:
    1991 318i ---- 308K - retired
  • mike.bmw
    • Dec 2015
    • 1777
    I just dug through a bunch of old photos and here's what I've found. Hopefully some of these will help:
    20200520_151506 by mike.bevels, on Flickr
    20200227_131214 by mike.bevels, on Flickr
    20191210_184538 by mike.bevels, on Flickr
    20191210_184230 by mike.bevels, on Flickr
    20191210_184510 by mike.bevels, on Flickr
    20191210_184246 by mike.bevels, on Flickr
    • mike.bmw
      • Dec 2015
      • 1777
      And one more for good measure:
      20171117_143831 by mike.bevels, on Flickr
      • jrobie79
        • Mar 2006
        • 2526
        looking for locations/what these plug into behind the dash as well. I think the white relay base is for the seatbelt timer? but the big relay, I have no idea where that gets mounted or what it's for.
