Stalls after starting engine
  • dice2012
    • Mar 2021
    • 97
    So I have a problem, I can no longer get my engine to run for longer than a few seconds. Tried starting it tonight, it started fine but then after letting go of the key it dropped down to ~500 rpm and had terrible idle then died. Happened a second time. Third time trying to start it just immediately died after letting go of key. Would this be because of fuel pump relay? What are the possibilities and how would I diagnose it? https://youtu.be/mkXckGxfwvo">https://youtu.be/mkXckGxfwvo" type="application/x-shockwave-flash" width="425" height="350">
    the big D
  • dice2012
    • Mar 2021
    • 97
    Update: pulled the air filter, found out that it was chock full of crushed acorns, leaves, sticks, rocks, you name it. Cleaned that up, sprayed the ICV with carb cleaner, put some electrical tape around the ICV hose because it had some cracks in it, she runs great now, I’d say even better than before. New air filter and ICV tube on the way
    the big D
