Original door lockbox screws (Phillips head) have been superseded by star bit with whatever finish bmw is using now. It's probably more effective, but it's not original and doesn't look as good.
Thankfully, it isn't immune to a strong dose of muriatic acid. Stripped to bare metal and replated.
Enjoy every moment what you spend with your car. Day by day you will see the work of your hands. My M3's restoration took seven years, they were the most memorable moments of my life.
Thanks! I've been following your build as well. It is very inspirational. Seven years is quite a long time! I'm sure much of it was spent acquiring parts - and its good you started that long ago because you have some beautiful pieces in your parts bin that are no longer available. Looking forward to seeing your progress as well.
Do you know the part number of the black part the covers the "silver colored metal part" that holds the wiring? Im missing this on my car and I am trying to track down a replacement.
I disconnected the fuel rail and injectors from the silver colored metal part that holds the wiring, then left the wiring in this metal trough thing (technical term)
I think it's under the same part number as the engine wiring harness, which unfortunately means it's NLA. I'll look again when I get home and see if it has a separate PN printed on it
