Thanks for viewing and for your advice , here is where im at with my suspension :
I have ordered the Ground Control Kit with the single adjustable Koni's , front spring rate 440 & rear is 650 . I now need to order a Sway Bar Kit and am having trouble deciding on what kit to get.
The main use for my car will be " Very Swift Mountain Runs" and occasional Auto Cross. Im NOT concerned with a harsh ride as this will not be my DD. I want to corner balance the car and know that a SB kit with adjustable end links is needed. As you guys know there are several SB kits out there in various sizes, please chime in with your opinion and why. Thanks in advance !!
Also on a side note , how will front and rear strut tower bars affect the handling after choosing a sway bar kit ?? I am planning on a S54 swap in the future . :thank you
H&R Front 22mm , Rear 18mm
Bimmerworld Front 22mm , Rear 19mm
Suspension Technique Front 22mm ,Rear 19mm
UUC Swaybarbarian Front 22mm , Rear 19mm
IE Front 25mm , Rear 22mm
Eibach Front 19.5mm , Rear 16mm
