Help with identification
  • Elton_LV
    • Mar 2015
    • 3
    Hi Guys
    Please could you help identify, pistons, cams and crank in the pictures below. Motor was built a some 10 to 12 years ago and never used.
    Regards
    Elton
  • Elton_LV
    • Mar 2015
    • 3
    Have picked up crank is OEM 2.5L sports EVO.
    Bump cams and Pistons ?
    • Elton_LV
      • Mar 2015
      • 3
      So I've found out it's a Turner Motorsport 2.5L stoker kit, thankfully I opened the ECU and saw the turner chip.
      Now just to find out if cams are EVO III, valves are larger and valve springs are MS springs
      • BlackbirdM3
        • 2773
        Pull the cam gears off and look at the front of the cams. They should have a letter on them. That is how you tell.
        Will
        '88 BMW M3
