Misfire under load
  • Court M3
    • Jan 2004
    • 6713
    Misfire under load
    -The car starts up is without any problems, but under load has a misfire and once warmed is more pronounced.
    Checked a few things today to see if there's anything I could do to fix it:
    Removed and checked the plenum to check for leaks (none found)
    Checked plugs and wires for correct resistance measurements (all checked ok)
    It was getting late so wrapped it up and tomorrow going to check TPS and CPS.
    Any other recommendations?
    Continuous For Sale Thread
    323i s50
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5611
    In my experience, most "mis under load" situations are traced to the ignition system.
    Your TPS isn't going to cause a misfire problem.
    Check your CPS resistance and also visually inspect the wire up and down to see if one of the three wires are broken or breaking.
    IDK if you pulled out all your plugs, but if you haven't, pull out each one and inspect for excessive fouling.
    • Court M3
      • Jan 2004
      • 6713
      Makes more sense, I'll start with plugs since I have a set only need time now...
      323i s50
      • Massive Lee
        • Sep 2006
        • 6785
        Bad sparkplug wires or sparkplugs. I suggest the wires. ;-)
        massivebrakes.com
        • Court M3
          • Jan 2004
          • 6713
          Follow-up, wires it was Lee! Thanks for the tip
          323i s50
