Turn-Key S14B23 (US)
  • bataangpinoy
    • Jul 2008
    • 1636
    Turn-Key S14b23 driveline for sale. ECU had failed, sent it for a rebuild. Installed the rebuilt unit, and it fired right up.
    I have receipts for the engine since the time of its purchase from Guten Parts, including the recent maintenance. I have for sale an S14b23 (US) driveline with approx 70,000 miles on it, ~10,000 miles of which I have put on myself before I stored the car.
    Before Guten Installed it in my touring, it received:
    All Intake Gaskets
    Z3 SSK with full bushing/shift arm bearing replacement.
    Alternator Bushing Replacement
    Spark Plugs
    Cooling system is practically new. I did a full cooling system overhaul in February 2014, with about 1200 in parts alone (labor was about 45 hours between myself and my business partner). Also replaced the selector rod/output shaft seal and the 32mm lock plate at that time. Car has been stored indoors since May 2014, as the ECU died and needed a rebuild. I have since had the ECU rebuilt, changed the IGN coil, flywheel sensors, and spark plugs.
    Aside from the entire E30 M3 cooling system and the s14b23, you’ll also get;
    Alternator
    PS Pump
    Trans
    Harness
    Ecu rebuilt by Programma INC.
    OEM Headers & Cat
    Driveline was also service with the following parts while under my ownership. The following list is just off the top of my head.(attached PDF contains a concise list.)
    -New Voltage Regulator
    -Poly Alternator bushings
    -Z3 ssk
    -OEM selector rod seal
    -OEM output shaft seal
    -Mishimoto Rad
    -OEM Water Pump
    -OEM Thermostat
    -HPS Silicone cooling Hoses
    -OEM Expansion Tank w/ cap & level sender
    -OEM Fan Shroud
    -OEM Fan Blade
    -OEM Viscous Coupler
    ECU rebuilt 6/7/15 by Programma
    OEM Bosch Ignition Coil
    OEM Bosch Dist. Cap & Rotor
    OEM Flywheel Sensors
    OEM Intake Boot
    I’m selling it because I don’t get to enjoy the engine; it makes its power at its rev limit (6500rpm) and I rarely even touch 5500rpm. It would shine in a car that got tracked regularly. I love the sound, the response and fun the ITB’s provide, but I need something a touch more practical and powerful for daily use.
    The engine is still in my touring, so I welcome you to come see it run, and feel it perform. It’s a healthy engine! I’m in no rush to sell.
    No trades. Currently running and in my touring, I will pull it once a deposit is placed. Located in 10924.
    Thanks for your time!
    Contact me at functionmotorsports@gmail.com for the fastest response.
    **8000 USD**
    My feedback:
    http://www.r3vlimited.com/board/showthread.php?t=186328
    http://e30tech.com/forum/showthread.php?t=74911
    Instagram:
    @gears_n_glory
    @functionmotorsports
  • bataangpinoy
    • Jul 2008
    • 1636
    bump
    My feedback:
    Instagram:
    @gears_n_glory
    • Downeaster1
      • Mar 2008
      • 85
      Is this still for sale?
      1985 325e Sedan, 1986 325e Sedan, 2006 BMW X5, 2012 M3 Sedan, 2013 135is, 2017 M3 Sedan ZCP Competition
