WTB: e30 m3 rear windows.
  • Rouvld
    • Sep 2014
    • 569
    Looking for a pair of e30 m3 rear windows. Let me know what you have.
  • jhaurimn
    • Nov 2012
    • 2224
    I recommend finding a pair of late model rear windows and painting the chrome strip black with duplicolor black trim paint. I did that on my m3 and you cant tell the difference between it.
    Get late model windows though, that way you only have to paint 1 chrome strip, compared to 2.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • Rouvld
      • Sep 2014
      • 569
      Haha I guess it's easy to tell what my goal is! Did the 88 m3 not come with shadowline from the factory? And aren't all e30 m3 pop out? I actually did my trim with the SEM trim black paint, then later I found out that you can get oem shadowlin new, so I bought it. I compared the new oem shadowline to my original trim painted trim and the match is close but the oem just has a ever so slight gloss compared to the painted ones. And I'm such a perfectionist that it'd bother me a bit seeing the slight difference. But if I am not able to find an original oem shadowline window I'll just SEM it.
      • jhaurimn
        • Nov 2012
        • 2224
        Heres the result of grey primer, then duplicolor black trim paint from autozone. I only painted the bottom strip, you can see where some flaked off when removing masking tape and a little chrome shows. But the match is very close. I am also very particular and I am satisfied with it ;)
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • Rouvld
          • Sep 2014
          • 569
          Damn that is pretty close, did you use spray primer?
          • jhaurimn
            • Nov 2012
            • 2224
            Yes, I'm pretty sure I used duplicolor grey sand-able primer, again from autozone. I didn't sand it, but you can if you are wanting it perfect.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
