WTB - E30 M3 front sway bar
  • mikerob97
    • Jul 2010
    • 140
    Hello, I am looking for a used E30 M3 front sway bar - prefer with no rust. Shipping to Raleigh, NC 27513
    PM or email to mikerob97@yahoo.com.
    Thanks - Mike
    Mike
    Cary, NC
    Current Rides
    1991 325iC - For Sale
    2006 M3 Cabriolet
    Past Rides
    2000 323i Touring - Daily Driver
    1994 325is (S50) - Fast Car
    1998 Z3 - Fun Car
    1986 325e (i engine conversion)
    1969 Mustang Mach 1
  • flyboyx
    • 8371
    i'm pretty sure its the same as a standard e30 bar. it's mounting point is on the strut instead of the control arm which makes it more effective.
    you would be best served to buy a cabrio front sway.
    Gigitty Gigitty!!!!
    • Bmwdayz
      • Apr 2011
      • 610
      Sway bars
      Using a Cabrio sway instead of the correct M3 sway bar will cause understeer. M3 sway bar is 19mm, 325i sway is 20mm and the carbrio is 21mm. If you can't find an M3 bar at least go for the 20mm 325i bar.
      • mikerob97
        • Jul 2010
        • 140
        Found one
        Thanks for your reply. I found an front M3 bar, thanks. However, your reply is very interesting - you are the first one that has advocated for using the M3 front bar.
        I have just about finished my winter suspension / brake refresh. The setup in my Cabriolet is, H&R sport spring with Bilstein struts and shocks. I am also running an M3 14mm rear bar. I have moved the front sway bar attachment point to the struts. I have both an M3 front 19mm and my stock Cabrio 21mm swaybar ready to install. - Now the dilemma - which one to install?
        Any additional thoughts?
        Mike
        Mike
        Cary, NC
        Current Rides
        2006 M3 Cabriolet
        Past Rides
        1998 Z3 - Fun Car
        1969 Mustang Mach 1
        • danderson
          • Jan 2010
          • 63
          With the strut mounted sway bark links I think the leverage ratio is different. So a 19mm M3 bar with M3 links acts stiffer than a 20mm 325i bar with regular links. Hope that makes sense.
          If you're running strut mounted sway bar links I'd try and stay with the 19mm bar. It's actually still available new from BMW if you can't find one.
          1991 318i
          • roguetoaster
            Biggus Tippus
            • 7800
            At last check all E30 sway bars were available from BMW, and they're reasonably priced. Well worth it IMO as you're not getting a 25+ year old spring.
