Details on the actual production and availability of these are coming, but I approached a local forum member about the possibility of building as close to a plug-n-play kit for the E30 5-lug conversion as possible. He came damn close.
These are E36 hubs and brakes installed onto an E30 stock spindle.
Here is the full flickr set:
Warning: have a tube sock handy.
http://www.flickr.com/photos/3790363...7623556051971/
Fully installed. A hex cap screw holds on the cover/key. Everything is SS:
Key removed showing the hub nut/spacer itself.
Spanner tool for installing/removing the nut/spacer:
Spanner tool installed in hub:
A little machining of the caliper bracket was required to clear the stock mounts, caliper adapter visible installed on the spindle:
Fully Assembled:
Spacer/Nut. Threaded to fit stock E30 stub axle:
In all it's glory:
Enlarged backing plate to compensate for the E36 hub/bearing. Presses onto the stock stub axle:
Face of the back plate. Raised area is the outside diameter of the inner race:
Caliper bracket to fit E36 calipers on E30 spindle:
Fitment with ABS sensor:
Just enough clearance:
Fully Assembled:
In all it's glory:
[IMG]http://www.r3vlimited.com/board/
