Are my arms z3 or 318ti?
  • BMW_TUNER
    • Jul 2006
    • 1386
    How can I tell for sure if my rear arms are z3 or 318ti? I have to figure it out asap as mine is busted.
    Ryan
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • dj01540i6sp
    • Jan 2009
    • 349
    Well all I can say is on my 2001 z3 that I installed on my 91 318is, The inner tie rod threads are much larger and require no locking plate and the outers has like a larger S bend on them, and has the same outer ball joint. Hope this helps GL.
    Sorry! Did I miss read? or was it corrected after reply?
    • 10Toes
      Me Father Was A Tree
      • Jan 2008
      • 61222
      This thread it for rear trailing arms?
      dj01540i6sp, your talking about front control arms?
      • BMW_TUNER
        • Jul 2006
        • 1386
        Corrected to clarify thanks
        • 10Toes
          • Jan 2008
          • 61222
          The 1.9 z3 and 318ti use the same part number for the trailing arm.
          http://www.realoem.com/bmw/partxref.do?part=33321091152
          • Aptyp
            • 6584
            At no point does this address any sort of arm, control nor trailing.
            OP: you ordered trailing arms that came with hubs, installed them and ran attempted to run high offset wheel. This alone leads me to believe that your trailing arms are 318ti/1.9L z3. But we've covered all this already.
            • BMW_TUNER
              • Jul 2006
              • 1386
              Got a 84 e arm
