Early e30 with 323 compact rear axle and 8,5x17" et 13
  • Krillian
    • Aug 2009
    • 18
    Teaser.
    Testing some parts i had in storage.
    Car is 320 -86 with rear axle from 323ti compact and the wheels are OZ futura 8,5x17" et13.
  • daniel
    • 6703
    very nice
    http://instagram.com/dslovn.drives
    • e30_325es
      • 1249
      interesting. what size tires do you plan to run?
      • MikeDE
        • 1873
        This^, I have the rear from a 318td compact and 8.5x16 et13 and would like to get an idea also.
        -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
        • jahnaboi
          • Oct 2006
          • 1742
          No way he's fitting more than 205 on that thing. Good luck trying to fit that on; at this point its more form than function to say the least.
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • Krillian
            • Aug 2009
            • 18
            Sry. have been busy. Ehm. 205/40x17" or 215/35x17" was the idea. And no these wheels are not going to fit the car. Why? Becuse they couldn't fit over the brakes at the front.
            so.
            17" Split rims + E46 330brakes *325mm = Fail. And 10mm spacers at front is nothing i want. The rear was ok. Friend of my is having the same setup/rims on his 91 cab
            Going to use 17" throwing stars from M5e34 insted, with 3mm spacers to clear the brakes at the front.
