GC Camber Plates which ones?
  • jahnaboi
    • Oct 2006
    • 1742
    Hey guys, so I've been running my gc coils and e36 m3 koni (top adjustables) all around. I was wonder, what gc camber plates should I buy? I heard, when I called GC that I have to use hybrid camber plates. When I look at it theoretically, if I get the correct diameter for the bearing couldn't I just use the e30 camber/caster plate? Or is the koni insert for the e36 m3's shaft diameter larger than 16mm?
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
  • BMW_TUNER
    • Jul 2006
    • 1386
    They will build them just for you. I run the new style camber caster plates with e36 billsteins and e30 uppers and they are great just call and tell them what you have and they will send you what you need. Btw the e36 struts with washers plus the GC plates will get you 4.5 degrees in the front.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • 36brua
      • 689
      no help here but... weird I was just chking their site came back here to search about their new 'touring' plates for e30
      My CA legal M60 swap
      The happening in our garage
