5lug swap question?
  • isra
    • 177
    5lug swap question?
    im doing a m52 swap, i have the 328i setting in my backyard, just want to know if i can use anything in the 328i to do a 5 lug swap?????
  • bimmer630
    • 1230
    You can use the whole front end, Knuckles/struts/brakes... but the wheels wont sit centered in your wheel wells. 96-up M3 control arms and E30 M3 bushings need to be used and even then the non M knuckles dont sit exactly centered. Get all M3 stuff.
    You can use the strut housings if youre gonna chop the perches off and put coil overs and konis or something like that though.
    none of the rear stuff will work, besides the brake calipers.
    Search the parts lists needed for this elsewhere in the 5 lug swap section. Theres alot of good info. after all the trouble finding the parts you need, it may make more sense just to upgrade the brakes on your 4 lug setup
    • nu-B
      • 85
      if you want to use the front stuff from your 328i. I have a pair of rear trailing arms, axles,
      break rotors and cali's from 318ti I could let you have them for 300$. let me know.
