In detail: 5x120 rear, using MZ3 rear trailing arms.
  • Jordan
    • 12916
    I just made a spacer for the e30 sensor so it was the right distance off the ABS ring... pretty simple.
    https://mtechniqueabs.com/
    • diegom6
      • 4447
      Jordan what did you use to change the front hub? I mean I see a nice write up of the rear conversion, what about the front? I would like to see it.
      I was thinking to try to swapp just the hubs from a e36 in my e30, but I didn't have a chance to see if they will bolt directly or not, do you know if is possible?
      Thanks
      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
      • asgardrune
        • Oct 2005
        • 1
        Hi, i read about your Z3-M rear axle.
        could you tell me if there are any problems with camber and toe when installing the Z3-M rear axle parts?
        some people told me that the Z3-M part has different angle's than the E30 part. My BMW dealer couldn't tell me and since the swingarms are quite expensive i wouldn't like to buy them before i know if they really fit without problems with camber and toe-in.
        from your pictures here i couldn't quite see if there are any differences.
        hope you can help me with that...
        • Jordan
          • 12916
          The e30 and MZ3 rear trailing arms are dimentionally identical in every way that matters to an alignment machine.
          The only real differences in the arm are the camber/toe renforcements, the 5lug hub, larger wheel bearing and of course massive brakes.
          • Slyder
            • 348
            Jordan, I think I've asked you this before, but I've since forgotten...
            Is this conversion possible only through the use of M Roadster/Coupe trailing arms, half shafts and differential flanges, or is it possible to use the regular Z3 Roadster/Coupe components in their place? Just thinking about it, I would imagine the Z3 trailing arms would be fine, but I'm not sure if the M's axle shafts and flanges are different.
            Thanks!
            Edit: Found the answer to the question in this thread, posts #5-6
            - Jason
