E28 ???
  • SA E30
    • 1248
    E28 ???
    Ok, I heard some where that the E30 M3 uses E28 hubs, and brakes ? If this is true, wouldn't u be able to use the parts of an E28 then to do a 5 hole conversion ?
  • Jordan
    • 12911
    It's not that simple. Some parts are shared, alot is still different though.
    https://mtechniqueabs.com/
    • SA E30
      • 1248
      Thanks, so the easiest way would probably be to do the Z3 rear, and E36 front conversion.
      • Jordan
        • 12911
        FWIW. I am using the MZ3 rear suspension/brakes.
        After much research and conversation about the e36 front I said "fuck that"
        It's so expensive to do it "right" and even then you are dealing with whacked out geometry.
        I chose to go with e30 M3 front strut assemblies, with the SBI rotor spacers so I could still have the e36 M3 brakes. Best of both worlds.
        • Axxe
          • Aug 2004
          • 3355
          What's the difference between MZ3 and Z3 rear supsension? Track width?
          Keep it slideways!!
          • Jordan
            • 12911
            Much larger brakes. Reenforced trailing arms, larger wheel bearings, etc.
            • SA E30
              • 1248
              So for me I would then go with the Z3 Trailing arms, and then possibly 325iS Evo Struts... BTW what do u mean when u say struts ?
              Thanks
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Thanks
                Strut tube assembly. Wheel bearing up to spring perch.
