Noob, has anyone tried making their own 5-lug hub?
  • Sagaris
    • Sep 2009
    • 2243
    What would be the problem with machining a new hub with a 5-lug bolt pattern? This seems like the easiest and most logical way to get the extra lug on each wheel. I have never researched this topic so flame away if I just asked a retarded question
  • AndrewBird
    The Mad Scientist
    • 11898
    People have talked about it, but I don't think anyone has ever followed through.
    • Quadrajet
      • Jul 2008
      • 1278
      I think I saw a discussion about this a couple years ago, and one of the things posted was how little material there would be out on the edge of the hub, plus fill and drill.
      • Sagaris
        • Sep 2009
        • 2243
        Well if I ever need a 5 lug swap then I will be a pioneer and make my own hubs for it. I mean, how hard can it be? :D
        I think a good start would be checking all the cars that share the same size bearing. I know the rears are the same as some Audis and Porsches.
        • pantelones
          • May 2011
          • 533
          I was just thinking about the same thing. I too thought about the fill and re-drill, but I don't think there is going to be enough material to make it structurally safe.
          This might sound stupid, but has any one tried to use an e36 hub? I have no hands on knowledge, but it looks like it could work.
          A man chooses, a slave obeys... Would you kindly?
          • JTapper
            • Sep 2009
            • 847
            It's not stupid. I did it.
            Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
            • bmwguy325is
              • May 2011
              • 1263
              I tried once. All i had was some wood and hot glue. It worked for awhile.
              I then did ask a machine shop. They owner drove an E36 and said hmmmmm
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • Holland
                • Nov 2008
                • 7212
                Why wouldn't one be able to machine an E36 sized and styled hub to match to a standard E30 bearing? Better yet an E30 M3 sized and styled hub?
                Originally posted by DEV0 E30
                • MaxBell
                  • 1391
                  This seems like the most simple way to go about getting 5 lugs...
                  Yes? Can we do this!? I WANT TO DO THIS!!!
                  REMEMBER: Be safe and have fun is Rule Number 1.
                  The Epic Unbuild of Clint Eastwood
                  • accident
                    • 7303
                    The E30 and E36 use the same rear wheel bearing, I don't see why you wouldn't be able to use an E36 hub in an E30 trailing arm.
                    Moral of this story?
                    • JTapper
                      • Sep 2009
                      • 847
                      I'm running this:
                      I was thinking of selling them, I wanted to run at least a season on them. No issues so far.
                      • kameleon
                        • May 2011
                        • 288
                        So will you sell them?
                        • E30m42cab
                          • Aug 2009
                          • 190
                          I've got a friend in Quebec interested in purchasing this same sort of setup. Any thoughts on moving forward with production?
                          • ose30
                            • Sep 2011
                            • 19
                            what would be ideal price of the new hubs? This is a new hub for the Porsche my friend has made. It would been really easy to fabricate similar to BMW as well.
