Using 325/328 coilovers with E36 Evo setup
  • Gouki
    • Dec 2006
    • 2
    Hi guys I have question that needs answering. I am gathering bits for my 5 stud conversion. I have the front setup from the 97 evo, hubs spindles brake calipers control arms. Can you use normal E36 coilovers 325/328. Will these bolt up to the spindles and line up exact?
  • SA E30
    • 1248
    Yes, they will.
    You just won't have the m3 sway bar attachement, in other words you would need to attach it to the control arm like a regular e30/e36
    • Gouki
      • Dec 2006
      • 2
      Originally posted by SA E30
      Yes, they will.
      So basically I use a normal sway bar (I'm assuming this is a drop link which we call it in the UK) that connects the strut to the control arm, correct?
