E36 5-lug; I'm switching to a softer, higher setup using E30 H&R OE sport springs for a daily driver cabrio. I pulled the PO-installed Bilstein sport struts out of my E36M3 front end. Confirmed from the P/N F4-VE3-A585-H0 that this is indeed a sport shock for the '97 M3. The replacement strut from KYB P/N 334938 is listed for '97 328is. BUT the new strut has a way bigger diameter spring perch and the total length of the KYB is way shorter than the Bilstein. I expected the KYB to be longer as it is designed for stock springs and the Bilstein is designed for lowering springs.
Where did I go wrong on these parts? does the E36 non-M have bigger springs for some reason? I thought all E36 had the same spring diameter, but who knows?
Thanks for any tips.
