e46 M3 Brake Swap
  • -negrito-
    • 91
    e46 M3 Brake Swap
    Quick question has anyone done this? I know you would have to do the 5lug swap but has anyone used brake calipers from the M3?
    The reason I ask is because I found in storage my brother's calipers, rotors, brake lines from his e46 M3. I'll do the 5lug swap if it works if not I'll just get Massive BBK and use adapter since I'm only using the car for street use only.
    Thanks in advance.
  • bimmer630
    • 1230
    http://ohiobimmers.com/forum/showthread.php?t=4177
    • quakerE30
      • Jul 2011
      • 50
      I know that once you have done a 5 lug swap you can use e46 330i front calipers and rotors/pads as they will directly bolt up. Thats what I plan on doing.
      LEVINE AUTOMOTIVE
      • bimmer630
        • 1230
        The 330 brakes fit right onto Non-M spindles though, which means if you use those spindles, your front wheels wont be centered in the wheel well
