adjustable lollipops to fix castor?
  • IrocE30
    • Nov 2011
    • 104
    When five lugging an e30 see that alot of people use m3 offset CAB to increase camber or use Treehouse racing eyeball arms. Now i know that when using non m steering knuckels or when not using 96+ contol arms the front tyres will be shoved toward the back of the wheel well. I haven't found anyone using adjustable control arm brackets to correct castor in these situation. Would a product such as AKGs brackets (http://www.akgmotorsport.com/catalog...Control%20Arms) have enough adjustment to correct castor no matter what steering knuckle, control arm combo used?
  • dirty30
    • 3092
    I had the AKG's and while they are really nice they do not adjust into themselves enough to compensate for the extra castor needed with the five lug swap.
    • bmwguy325is
      • May 2011
      • 1263
      Maybe try the full AKG control arm set up
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • upyerheart
        • Jul 2012
        • 16
        The AKG's dont compensate for only 0.5" - 1" of caster? Surely an adjustable arm can extend by that much?
        • DTMbimmer07
          • 1485
          but can there control arm set handle being driven on normal roads? they are made out of aluminum.
          • upyerheart
            • Jul 2012
            • 16
            Well that depends on what grade of ally its made from. SOME alloys are stronger than steel. Just depends on what they have used to make them..
            • DTMbimmer07
              • 1485
              I'd like to know who is running these on the street and get some feedback from them. I deffinetly wouldnt mind picking them up but for 1800 dollars i dont want to destroy them running them on the street.
              • dirty30
                • 3092
                They are going to be noisy but you should already have expected that seeing how they utilize a spherical bearing instead of a rubber bushing. Judging by how beefy they are and being made by an extremely reputable company like AKG I'm sure they could handle whatever abuse you throw at them. Like I said they don't adjust in far enough to center the wheel in the wheel well opening with the five lug e36 stuff.
