Using m3 front struts/hub yada yada
This topic is closed.
  • gazellebeigem3
    • Jun 2005
    • 3712
    is this bolt on? Do you need control arms also?
  • Jordan
    • 12916
    Yes its bolt on. Use your stock control arms, struts, and springs/hats etc
    You will need to have the car aligned after as the tierod boltup point on the e30 M3 hardware is quite a bit spaced out from the normal e30.
    https://mtechniqueabs.com/
    • rede30
      • 4697
      Do the e36 m3 calipers bolt up on the front e30 m3 setup?
      • Jordan
        • 12916
        The calipers are a direct bolt on yes. You have to use e36 M3 rotors with them, and to center the rotors in the caliper jaws you must use SBI's rotor spacers.
        • gazellebeigem3
          • Jun 2005
          • 3712
          thanks for the info
          • gazellebeigem3
            • Jun 2005
            • 3712
            is there a difference between the m3 rotors and standard e36 rotors? If i were to go with 325is rotors and calipers would i still need to space it or are they smaller than the m's? Also which caliper brackets would i be using? e30 m3 or e36? or does it matter?
            • Jordan
              • 12916
              normal e36 325i rotor are small.
              e36 M3 are huge.
              • gazellebeigem3
                • Jun 2005
                • 3712
                e36 M3 are huge.
                so thats a negative on the spacing?
                • Jordan
                  • 12916
                  I don't know.
                  No one would ever fuck with normal e36 shit. Not worth the time.
                  used/rebuilt e36 M3 calipers are dirt cheap, and so are the new rotors.
                  Don't fucking halfass it!
                  • gazellebeigem3
                    • Jun 2005
                    • 3712
                    I don't know.
                    im with ya, i can get the calipers for 45 bucks a pop through work! but i dont have the fundage for the 17s needed for clearance. Also i happen to have an e36 parts car with all new brakes (calipers et all). It would be temporary and still and improvement over stock. Besides, once i have the suspension componants in, its not like it will be hard to upgrade in the future.
                    • Jordan
                      • 12916
                      If you do not have the money to perform the swap.. here is an idea.
                      wait for it
                      wait for it....
                      DON'T DO IT.
                      Or shit.. at least wait till you have the money to do it right.
                      • Addissimo
                        • Mar 2004
                        • 1820
                        Doing something M50 related? -> http://www.addissimo.com
                        On Myspace? ->http://groups.myspace.com/r3vlimited
                        BF2142 SN = BillyGoose
                        • Joe318is
                          • Sep 2005
                          • 6451
                          did you not read it? he has all thats shit for FREE, as well as the fact that the rotors are already bigger then stock e30's.
                          Theres no fun in going all out the first time, cause then you go no where from there and end up getting bored with your car, aint that right jordo?
                          Originally posted by vlad
                          • Jordan
                            • 12916
                            I still have plenty of upgrading to do.
                            When I get bored of these brakes I can install the e46 floating rotors, with 850CSi 4pot Brembos.
                            Wha? You didn't know?
                            • Joe318is
                              • Sep 2005
                              • 6451
                              More upgrades!!111 Maybe then you can find a girl thats NOT one of your relatives to pose on your car. Speaking of which, you may want to solve that oil leak before hand.
