Rubbing in the Front?
  • glucklich21
    • 1912
    So I got the last of my 5 lug sorted and installed on the car. Moving the car around out of the garage I noticed that my tires are rubbing the inside fender wells to death closest to the firewall on sharp turns. Is this normal or do I need to take a sledge hammer to it? :)
    Specs:
    BC E36 Coils w/ E30 camber plate
    96+ OEM M3 Control arms
    OEM E30 M3 offset CAB
    95' E36 M3 spindle
    Hartge 17x8 et40
    Nitto Neogen 225x45x17
    • 37829
    Well, your tires are oversized which isn't helping.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Wishno87
      • 6025
      Those tires will rub regardless of the number of lugs you have. 225/40 would be what you want if you need 225s.
      • glucklich21
        • 1912
        I couldn't find a tire with 40 aspect ratio. 45 was the closest in a 17. I know people have run them on their 5 lug swapped cars because I stumbled upon them when looking for what tire size for a 17x8.
        • rkettner
          • Jun 2007
          • 367
          I get rub with 225/45 but not my 225/35. However I could use a bit more sidewall
          • AirDoc
            • Sep 2006
            • 29
            From what I've been reading - you have all the right stuff...but need the 96-99 M3 spindles for proper caster/wheel orientation.
            Nitin G. Shanbhag
            BMWCCA #101510
            76 2002, 88 M3 Racecar, 88 M3 2.5, 95 M3 Slicktop, 96 E36 Trackbeater , 97 M3/4 Slicktop
