Difference between Z3 and M Z3 trailing arms
  • nitro325is
    • 495
    Okay so I have so far compiled all four M Z3 brake calipers and rotors and front e30 M3 Hubs.Still need to get sbi front kit.
    Question on the rear though. Cant source M Z3 trailing arms but have plenty of offers on trailing arms from Z3 2.8 . What is the real difference between these and the M spec. Will the M Z3 spec rotors and calipers bolt up to the Z3 2.8 trailing arms/hubs?
  • AdamF 88iS
    • 2051
    They should be interchangeable, but the M spec ones have a couple of reinforced areas. The non-M ones are pretty much the same spec as E30 arms.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Addissimo
      • Mar 2004
      • 1820
      according to jordo, they are completely different arms ( just double checked and they're different part numbers). I guess the bearing housing is larger in the mz3, which is why you cant use the mz3 output shaft and bearings in a normal trailing arm.
      As far as brakes, I think you'll be stuck with the tiny z3 brakes, unless you want to engineer a setup using wilwood components, or somethign similar (my plan using m3 trailing arms).
      good luck, I'm on a similar quest.
      -Addis
      Doing something M50 related? -> http://www.addissimo.com
      On Myspace? ->http://groups.myspace.com/r3vlimited
      BF2142 SN = BillyGoose
      • Jordan
        • 12916
        Nothing on the non-m arm and M arm (brakes included) can be swapped.
        Either or man.
        PS. We have a set of 1.9L Z3 rear arms complete with brakes etc here at TSA if you would prefer something local.
        https://mtechniqueabs.com/
        • nitro325is
          • 495
          yeah I was hoping otherwise. Ill think about those Z3 units Jordan as Id much rather drive to Austin instead of Houston.PM me price info.
          Dang I just dont want to look like a dork with pizzas in front and cookies in the rear.
          • Jordan
            • 12916
            I can't get you a price qoute man, sorry.
            Call (512)442.1361 ask for Rhett. Tell him who sent ya and whatcha need.
            He can price you out.
