Z3 M Roadster Front Spindles
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Simple question.. Does anyone know if the front spindles / suspension from a 99 M Roadster has the same geometery as the 5 lug spindles from a 96-99 M3?
  • Jalves619
    • 596
    As far as I know they are the same parts. Quick search on Real OEM agrees
    http://realoem.com/bmw/partxref.do?part=31212227907
    http://realoem.com/bmw/partxref.do?part=31212227908
      • 37829
      Yes sir, same parts.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • RobertK
        • Jun 2005
        • 5864
        Frickin sweeeeet
        • RagtopE30
          • Dec 2010
          • 1869
          I know I am bringing this back from the dead but I will have the complete front suspension from a 1999 m roadster very shortly. It has been established that the spindle is the same but I noticed that the strut tube has a different part number between the e36 and the m roadster. Can the m roadster front strut tubes be used in the e30? do they bolt up?
          450whp 524 lb-ft 1988 336ic In progress
          http://www.r3vlimited.com/board/showthread.php?t=250709
          • RagtopE30
            • Dec 2010
            • 1869
            Nevermind, Im apparently still a newbie. I found the info by searching and searching.
            • emripires
              • Dec 2015
              • 74
              It'll work just fine!
              • bimmer630
                • 1228
                I had a used set of M roadster struts, and one of them had a longer shaft in it for some reason. I dont know if they both came out of a roadster or if one was from a coupe etc... but just something to look for
