Another option for fixing caster?
  • !kid
    • 1362
    Couldn't the control arm mounting point on the e36 spindle be moved to fix the caster? it could also be done in a way to fix roll center and gain more steering angle for us that drift.
    what are your thoughts?
    :borg:
  • shEck3lls0
    • Jan 2011
    • 1154
    I suppose you could cut the brackets on the strut tubes and do a custom tab welded to the bottom of the tube that mounts to the non-m spindle. That way you could still run the non-m brakes as well.
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
