Originally posted by Jordan
If I drop it down further the Camber & Castor will increase, like any E30!!
As for dropping it to the ground, I'm sure you are fully aware that lowering a E30 to that extent is more detrimental to handling, excessively lowering the Roll Centre & thus increasing roll couple, and the massive toe/camber change on the backend (but we won't start on how vastly inferior my hacked up E28 backend is shall we :)).
In fact I probably still have an alignment sheet from my E30's old 4lug sacked out days, I'll try to find it, from memory it was pretty ugly!!!
So do we get to see your alignment specs and then explain why your 5lug setup is so superior (from a geometry point of view)??
Or should we take the lack of evidence as you admitting the E36 5lug swap is a perfectly good alternative to the E30 M3 5lug swap?? And doesn't give "horrid" alignment specs as you have previously claimed (also without evidence).
Don't get me wrong Jordan, I'm not trying to break your balls or anything.
As the saying goes, There are many ways to skin a cat, they all have the same outcome no matter how you do it or what you use.
Just 'cause you did it the easiest way (all OE bolt-on parts) and I used a bit of ingenuity doesn't make either way better or worse.
