M double spoke II rims on e30 Touring (5 lug setup) question.
  • purebmw
    • 35
    Hi guys, just wondering, have a set of e36 M3 96+ M Double Spoke II rims, 17x 7 1/2 Front, 17 x 8 1/2 Rear ET41 all around, using a Z3 rear crossmember with trailing and everything, will it rub? what kind of springs ?, tire size?, Do i need to use Rear crossmember shims to eliminate the rear negative camber?
    im reading about it... you know, measure twice, cut once... haha
    e30 325i 1988 track toy
    e30 M3 1989 M106 motronic swap (in process)
    e36 M3 1995 S50B30 turbo
    e38 750il M73N
    Toyota Tundra 2UZFE (workshop car)
    BMV Motorsports Guatemala
    • 37829
    If you have 6 cylinder Z3 trailing arms do NOT run them. They are too wide for the E30 and you'll never get any decent tire to fit on there even with a high offset wheel. You need to install the Z3 hubs and brakes in to the original E30 trailing arms. More info can be found here: http://extradrei.com/5lug.html
    For tires I would recommend either 205/45/17 or 215/40/17 in the front and 235/40/17 in the rear.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
