E28 535i Hub assembly swap to get 5 stud
  • pussy
    • Aug 2005
    • 34
    #31
    i believe the reason here of using the e28 rear arms are for the strength you need if you using 300+ hp..
    a friend of mine used structure foam on the subframe and arms and it added some strength to it..
    maybe it works..
    • MR_SAZ
      • Apr 2005
      • 74
      #32
      guys i found this recently...mentions front legs E30 4 stud to E28 5 stud here:
      looking at it...it seemed very interesting, E30 M3 front legs and u can have an E28 5 stud conversion....but i`m not exactly sure how it all works...
      anyone??
      Signature removed by R3V staff due to a violation of the forum rules
      • ldsbeaker
        • Aug 2004
        • 3098
        #33
        no shit.
        Guess what I have in my garage?
        TWO E28's!! (one's going to be my DD, the other is a parts car. Guess I need some more parts, huh?
        Now, if I can ever get my 535is going, I could actually check the validity of this for you guys....
        Stay tuned!
        Slicktop City!
        • Rocla
          • 922
          #34
          anyone??
          I researched this eariler, and came to belief that it doesn't work... I never spotted that page earlier, anyone?
          $750 is a steal, realoem tells $184/side I know realoem prices can be very off, but 750 is insane.
          EDIT: e28 strut has 3 mounting bolts while e30m3 has 4.
          EDIT2: Asked the local price for "legs", 155e/each I think I'll be ordering on just to find out.
          Current:
          BMW 320i 2d 2.0 m20 -88
          BMW 325i Cabriolet 2.5 m50 -88
          BMW 316i touring 1.6 m40 -90
          BMW 320i 4d 2,2 m54 -01
          • Rocla
            • 922
            #35
            Come on guys, this should be the ultimate solution to achieve 5*120 and big brakes with low price and no one knows nothing about it.
            Current:
            • Eric
              • 5138
              #36
              i need those legs since i have E30 m3 struts now!
              • sbullard878
                • Dec 2005
                • 183
                #37
                hmmm
                Will the e30 m3 lower steering knuckle really bolt up e28 front strut housings?
                Bmw 332i 260whp 240wtq N/a
                Lexus GS400 280whp
                • PiercedE30
                  • Apr 2005
                  • 4220
                  #38
                  No.
                  My 2.9L Build!
                  • Rocla
                    • 922
                    #39
                    Originally posted by PiercedE30
                    No.
                    Fact? I'm quite sure it won't, but since those guys sell the arms for that purpose....
                    Current:
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      #40
                      It won't. E28 and others use a 3 bolt mounting system while the E30 uses a 4 bolt.
                      My 2.9L Build!
                      • Rocla
                        • 922
                        #41
                        Yes, but i measured that the bolt holes are still on same pattern, so will it bolt with 3 bolts? Bad idea anyways.
                        E28 has brake caliper mounted on front side of hub, when e30 one is on back side of hub, that would most likely be a problem.
                        Current:
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          #42
                          I'm running E28 535i calipers on M3 strut housings. Same mounting holes but with a slightly (4mm) larger bore diameter.
                          My 2.9L Build!
                          • 2002maniac
                            • 4260
                            #43
                            could you install the passenger side strut on the drivers side and vice versa. If you couldnt, you could always switch the calipers. i cant see how front mounted calipers would be a problem.
                            I may have to order one of the M3 lower knuckes to check this out.
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              #44
                              No, you are not hearing what I have said. E28 strut housings do not have the same bolt pattern on the bottom of the housing. They use a 3 bolt mounting system instead of a 4 bolt system.
                              My 2.9L Build!
                              • 2002maniac
                                • 4260
                                #45
                                yes, but they appear to be on the same pattern (rocla claims to have measured it). I'm going to get my hands on these parts to be sure, but I think you could just use three out of the four holes or machine the bottom E28 housing for a 4th hole.
                                I already have big brakes and 8" wide wheels for the 4-lug but I'm unhappy with wear and tear on the wheel bearings. This could be a great low-buck solution.
                                E30M3
                                E28
