Advantages of 17in wheel on 5 lug?
  • graphikg
    • Jan 2008
    • 1614
    I am going 5 lug and I have been searching high and low for a good 16x8 wheel I like. I havent been seeing anything I like.
    I came up on a decent deal on a set of LTW e36 M3 wheels. I am thinking of going with these but what are the advantages?
    Are they light?
    Will they fit M3 brakes without spacers?
    Will it rub?
    I am planning to be on Variant 1 coilovers... so will these wheels even work?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    So, you are asking if e36 wheels will fit on e36 front suspension with coilovers installed?
    Yes, absolutely.
    The only concern will be what you use on the rear for the 5lug conversion.
    • Poorboyz
      • May 2012
      • 2117
      Just remember that when you go 5 lug with E36 components you will have to use wheels that have the same offset as E36 wheels. Wheels with +20 offset or less will not fit as the E36 suspension components push out the wheel hubs out a little compared to a stock 4 lug E30 hub.
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • graphikg
        • Jan 2008
        • 1614
        Well - I'm using a rear 318ti setup and non-M e36 front.
        I'm planning to use the LTW e36 wheels but want to make sure it fits, doesn't rub, and it's not too heavy.
          • 37833
          Yes they will fit. Are they staggered?
          Grover Beach, California
          BimmerHeads.com
          • graphikg
            • Jan 2008
            • 1614
            Yes. 17x8.5 rear. 17x7.5 front I believe.
              • 37833
              You'll need to run smaller tires than they originally came with though.
              A friend is running 205/45/17 front and 235/40/17 rear with his 5 lug E30.
              If you wanted a more low profile look and don't need it to be meaty you could go 205/40/17 front and 215/40/17 rear.
              BimmerHeads.com
              • graphikg
                • Jan 2008
                • 1614
                So I probably will be rubbing with the 245s? I don't mind rubbing on full lock of the steering; just not when going straight.
                And I will also be on coil overs; so I will be able to adjust height.
                • graphikg
                  • Jan 2008
                  • 1614
                  I found out that:
                  Front LTW Wheels: 17x7.5 - 225/45/17 tires
                  Rear LTW Wheels: 17x8.5 - 245/40/17 tires
                  I am hoping they wil fit...
                  And I hate to add another topic to this, but I have some curiosities since I have never done this before.
                  My coilovers are Variant 1s and I have a full non-M front setup (brakes, spinles, CAs, etc). Am I going to need M3 spindles to make everything to e30 alignment specs?
                  I have been reading around, and it seems like I am going to need M3 spindles and CAs on the coilovers to make sure everything is at e30 specs.
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    96+ e36 m3 control arms but yes, to get close, you'll want the m3 stuff, and the e30 upper strut mounts, and this is the reason people go 17's because it's easier to find 17's that clear than it is the 16's out there. (In most cases)
                    • graphikg
                      • Jan 2008
                      • 1614
                      Oh man...
                      Now I have to source out some M3 spindles and buy new 96 M3 control arms?
                      Gees, I thought I had it all. This is going to cost more time and money than I thought.
                      Once I go with the 96 M3 control arms, what can I do with sway bar link? I have an e30 sway bar with the short link. How do I work out the sway bar and the link situation with the 96 M3 control arms?
                      • IronFreak
                        • Dec 2012
                        • 3702
                        I have about $2700 in my 5-lug swap.
                        all 98M bits
                        z3 rears
                        GC coils and camber plates
                        Konis in all four corners
                        Eyeball CABs
                        New rotors/pad and caliper rebuild kits.
                        5-lug isn't cheap homie
                        Instagram @rebellionforge
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Buy m3 specific coilovers, and buy adjustable links.
                          • graphikg
                            • Jan 2008
                            • 1614
                            You guys can flame me all you want. I bought the wrong things. I think I'm just gonna fix my GE coil over stuff and stick with 4 lug. :/
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              Dude, neither of our posts were flames. You didn't buy the wrong things, you just didn't buy the right ones. No problem.
