5 Lug conversion completed, Still having problems. Help!
  • el bimmer
    • 900
    As the title states, the 5 lug has been completed for some time, but I haven't had time to do much to the car since. I've moved and now has started to work on it again.
    For those that don't know my set up, I have e36 M3 front and 318ti rear. Currently, I am running e38 Styles 5 with 205-50-16 and I am rubbing in the inside (pictures 1) as seen in the picture. I am also using e36 M3 struts with e30 perches.
    I also have some concerns, please take a look at my pictures and give me some ideas of what am I dealing with here.
    I take criticism well and yes I've researched the problem and have taken into consideration and tried spacer and still rubbing.
    Thanks!
    I thought this was not suppose to be straight at all.
  • nrubenstein
    • 3148
    Get wheels with an appropriate offset, or switch to E30 M3 parts.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • el bimmer
      • 900
      Which ones do you recommend?
      • E30-323ti
        • 328
        ...or lower profile tyres (45's say).
        Higher offset rims (such as OE E36 ones) will scrub less (move fore/aft relative to the steering axis) than the low offset wheels you have.
        292rwhp E30 :D
        • el bimmer
          • 900
          I almost think I need to move the front wheels forward, maybe needing camber plates. If you notice the pictures, the rims are not center on the fender, they are more towards the back. IMO that's why it's rubbing. What do you think?
          • nrubenstein
            • 3148
            Offset control arm bushings will help with clearance from the rear. Still won't change the fact that those wheels should never be used with E36 suspension components (roughly equivalent to running ET0 on stock E30 parts), and on top of not fitting, absolutely look like ass that way.
            Sent from my iPad using Tapatalk HD
            • el bimmer
              • 900
              The pictures posted are with 12mm spacers which in fact you are right, it looks like ass.
              I'm confused there are other using the same set up on mines and are able to use the rims with no problems.
                • 37833
                Can you confirm you're using 96+ E36 M3 control arms AND offset control arm bushings?
                Grover Beach, California
                BimmerHeads.com
                • el bimmer
                  • 900
                  Yes I am sure! I bought everything oem.
                  • decay
                    • 5637
                    spacers are only going to make the rubbing issue worse. leave them off, and be prepared to clearance with a BFH and pull the fenders if you want to use these wheels.
                    otherwise, yeah, get something with an e36-appropriate offset like Nick said.
                    edit: if you bought everything OEM, you might still need the right bushings...
                    past:
                    1989 325is (learner shitbox)
                    1986 325e (turbo dorito)
                    1991 318ic (5-lug ITB)
                    1985 323i baur
                    current:
                    • el bimmer
                      • 900
                      Got it thanks! So basically i need offset bushing. I really appreciate all of you guys input!
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        Did you install the offset bushings correctly?
                        Originally posted by codyep3
                        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                        2001 silver/Blk 325 cabby. SOLD
                        2002 325xit Sil/blk. SOLD
                        2010 F650gs twin
                        • el bimmer
                          • 900
                          Honestly I'm not sure at all. It was such a long time ago that I installed them. I probably did it wrong.
                          • franky2fingaz
                            • Aug 2012
                            • 117
                            Take a brief look under, the control arm to bushing connection location in the lolly-pop should be towards the outside of the car... but your setup is centered, your issues as some stated are:
                            Spacers are exaggerating the swing of the steering = more rub. The wheel will hit the front caliper retaining spring when the spacers are removed, some shave it or do without it but I personally wouldn't recommend as pads will flap around as you drive.
                            The wheels, E36 stuff increases track, good for handling but must increase offset, 8" rims with +23 offset is just past the limit, again exaggerated by the spacers. This is why I opted for the 16x7.5 ET20 from an E31, tucks things a bit. E38 had the same size in the style-15 and another slotted rims but very hard to find.
                            E38 750IL rims at 16X8 ET23 (two rim designs that mimic Alpina) should clear the calipers with out spacers.. need verification.
