Great pictures. can you tell what vented rotor and caliper would work in that setup?
Z4 rear hub
[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction FeedbackComment
SOLD OUT !!!
<< ORDERED and PAYED >>
1. 01012011 - Arrived
2. e30m3s54turbo - Arrived
3. BMWSAAB - Shipped
4. Shftr8 - Shipped
I will make them for next batch, each batch 5 sets
Thank you for all buyers..
for helping unemployed member to build e30 m42 2.3L stroker rice car :DLast edited by ngampleh; 03-10-2016, 06:20 AM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
update
3. BMWSAAB - Arrived
4. Shftr8 - Arrived
I am making new batch for 5 sets
Will be ready to ship soon..Last edited by ngampleh; 03-18-2016, 05:58 AM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
if you confirmed want to use this setup, pls get in the list..
>>> ORDERED <<<
1. Eavan (FB) - Ordered
2.
3.
4.
5.
thanksLast edited by ngampleh; 03-18-2016, 06:34 PM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
idk if the realoem says same caliper bracket...
but when I look deeper, is same with 323i coupe, vert and touring..
just take it from e46 325i or 328i one for make sure will fit..
323i have smaller rotor diameter (276x19)..
you can use caliper from 323i with 276x19 rotor diameter,
but you need to change caliper carrier with 325/328
p/n: 34216758134
http://www.realoem.com/bmw/enUS/part...&q=34216758134[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
update from CNC shop
if you confirmed want to use this setup, get in the list..
>>> ORDERED <<<
1. Eavan (R3v FB) - Ordered
2.
3.
4.
5.
thanks
5 pcs right brackets done, need to make left one...
will be ready to ship next week..
Hi there, very interested in ordering a set of these.
I was just wondering what hoses would you need for 330i calipers? The ones from the e46 or the ones standard on the e30 and is it effectively bolt on or do I need to make and flare custom hoses?
Secondly for those running e46 330 calipers, what booster and master cylinder are you using? I'm thinking of upgrading to the 25mm master cylinder that's supposed to be 'bolt on' from a 7 series and I'll probably do the e34 booster when I do my m60 swap but was wondering will this be enough/is anybody using that set up or similar??
TIAComment
hi Tia,Hi there, very interested in ordering a set of these.
TIA
for the hoses 330i brake caliper, there are many option...
depend on your capability to mod it or get the parts, here the option is;
1. use same as my setup
2. use e30 front hose
3. use stock hose with some m10 male/male elbow + female/female adapter
I used stock e30 booster and e30m3 or e28 master cyl with 23.81mm dia.
and here how to fit the bracket to use 330i rear caliper and retain stock e30 e-brake
pm'dLast edited by ngampleh; 03-23-2016, 09:45 PM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
