Z4 rear hub
[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction Feedback -
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
Transaction FeedbackComment
I want bigger brakes and I use e30 51mm struts.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
I see, e36 m3 suspension will only maximum 315x28mm right?
My rear setup will be maximum use e46 330i..
But in my place, 330i caliper quite expensive and rare..
My friend, build BBK from e92 335i brake for both front and rear anyway
348x30mm front and 336x22mm rear[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
I bought 330i calipers and rotors used for $150 at a wreaking yard in San Diego.
The 330i is not rare over here in California.
Is your friend using 17" or 18" wheels 348x30mm?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
He is using 17" weds tc05
Pretty cheap, is $150 for both front and rear calipers and rotors?
I bought e46 325i front calipers and rear calipers + rotors for $330 from wrecking car..
If you are interesting to use 348x30mm rotor, need to consider rotor weight..
25 lb each rotor
Last edited by ngampleh; 08-04-2014, 09:48 AM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
sorry, I have no idea yet...
need to customs 2pcs rear rotor, IMO
I dont have z3 trailing arm here, so I cant help you..
big different rotor height is the problem
z3 is 76mm
330i is 60mm
huge gap.. need more narrower offset 16mm
if you need the e brake work properly..
consider to looking hub with narrower offset[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
How thick are the 300mm.de adapters? I've always thought the use of spacers on top of them was a bit daft...On my rears I'm using 318ti trailing arms with 300mm De. Adapters, z4 3.0 rotors (294x19mm vented) e36 m3 calipers. The fronts are e36 m3 set up for now. I will be swapping Max e30 5 lug kit with 330i (325x25mm) rotors and 330i calipers.
I would like to see how the z4 hubs work out.Comment
Dimension : 129 x 49 x 11mm
I saw on your paper
Sent from my iPhone using Tapatalk[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
Front kit has arrived from Lithunia
But it came with crappy nut...
See right one..
Have to wait replacement nut another couple weeks, though
Also, I made my own design nut on shop.. because time is money
As you can see, the thread didnt made well..
Too big for the minor diameter
Rear bracket finished from shop
And light weight spacers for rear
Sent from my iPhone using TapatalkLast edited by ngampleh; 08-31-2014, 07:52 AM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
