i6 z3 hub question?
  • kickinindian
    • 2327
    i6 z3 hub question?
    so to fit this on an e30 TA, keep ABS (with spacer correct?), and keep stock ebrake, all i need is the z3 hub, and what rotors and caliper/brackets?
    i plan on using the hub spacer thing, from lithuania on the fronts.
    • 37833
    Yes the 6 cylinder Z3 hub will fit in stock 86+ E30 trailing arms. You'd use matching Z3 brakes.
    Grover Beach, California
    BimmerHeads.com
    • kickinindian
      • 2327
      Tausend dank!
      • Self Made
        • Jan 2015
        • 153
        What about the front? Can you use Z3 I6 hubs/breaks on E30 struts? Or the whole Z3 I6 struts?
        If not what set up can you use? I know E36 M3 stuff works but the breaks are bigger, doesn't that mess it up?
        Thanks
        Matt
        • kickinindian
          • 2327
          Thanks
          Matt
          buy this for the front and u can use e36 brakes and hubs on your e30 suspnsion stuffhttp://www.r3vlimited.com/board/showthread.php?t=306268
          • Self Made
            • Jan 2015
            • 153
            Wow thanks, idk how I didn't see this before
