5 lug help
  • henna 3ree
    • Jun 2011
    • 124
    5 lug help
    Good Morning!
    i have a chance to buy a 4/1997 z3 rear trailing arms and brake's for a good price but i don't know if they will work on my e30 for a 5 lug conversion. Anyone with knowledge on this subject please help.
    33321094761
    33321094762
    thank you in advance!
  • dirty30
    • 3010
    you dont want those Z3 trailing arms unless you want to swap to Ti hubs
    look here:
    • Artful Dodger
      • May 2008
      • 156
      5 lug rear is easy.
      If you already have a 325i or is, buy Z3 6cyl hubs, new bearings and press out the old bearings with the old hubs and install the new components.
      This will get you rear 5 lug that will fit stock e36 wheel fitments. IE 17x8.5 et 40.
      as for brakes, I used Z4 rear rotors. these are vented instead of solid. But, I am using aftermarket calipers, so this my not work for you.
      • jph
        • Feb 2015
        • 463
        Originally posted by Artful Dodger
        5 lug rear is easy.
        Is there any difference between 6 cylinder Z3 hubs and E30 M3 hubs in the rear? Do the Z3 rear hubs cause a change in offset from stock?
        • Artful Dodger
          • May 2008
          • 156
          I dont know about the other hubs, but the stock e30 hubs are good for an ET 20 wheel. The z3 6 cyl hub in the e30 arm is good for an ET 40 wheel. So the Z3 hub is 20 mm further out from the bearing then the e30.
          I dont know about the e30 M3.
          • jph
            • Feb 2015
            • 463
            Ok, thanks. Good to know. I THINK the E30 M3 rear hubs retain the factory non-M hub face location. This is based on the research I have been doing.
