standard non M3 e36 ground control coilovers?
  • alpineE30
    • Aug 2007
    • 81
    Anyone running these on the front I already know the rears wont work. I found some used ones but Im wondering if they will work out and what about the upper strut mounts? I thought I would ask before buying them and they didnt work out. thanks
  • mtech325
    • May 2008
    • 569
    If you're doing coilovers, the non-m struts should work up front, but you'll want e30 mounts or camber plates. Non-M e36 doesn't have the sway bar tab on the strut (unless ground control welded the tabs), so you'll have to have the sway bar mounted to the control arms like a non-M e30. Still use the m3 spindles/knuckles to get the most caster possible.
    • alpineE30
      • Aug 2007
      • 81
      Alright thanks thats what I needed to know.
      • alpineE30
        • Aug 2007
        • 81
        Anyone know the average price to pay for used front ones with konis?
