Spindle Damage
  • apiazza2010
    • Nov 2013
    • 131
    Spindle Damage
    I have a 5 lug swapped e30, I was doing a front wheel bearing change and I made the dumb mistake of just hammering out the adapter sleeves from the old bearing race.
    This unfortunately crated a small ridge on the adapter sleeves that i didn't see. Reinstalling the nut seemed excessively hard, therefore I decided to take it back off and see what the problem was.
    This is the result
    My options are:
    1. Get new bearing, clean up both surfaces, reistall and be done.
    2. Get new spindle, new coilover lower mount, cut and weld it, get new inner and outer sleeve, new bearing, reinstall.
    It's a V8 swap that I bring to the track, what do you guys advice ?
    LS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
  • bimmer630
    • 1230
    Is that an E36 knuckle or the E30 knuckle with the bearing adaptor? hard to tell
    • 328ijunkie
      • May 2007
      • 3961
      This same thing happened to me :|
      Check Us out on Facebook
      Full Product Line Tuning
      • Jb325is
        • 2137
        I always did worry about serviceability with these kits, if you are running the car on the track I wouldn't re-use either part
        - '88 m54 coupe
        <3
        • 328ijunkie
          • May 2007
          • 3961
          throw away spindle?
